FAQ Motor vehicle for separating the engine from the transmission - special tool
Germany Joachim
Administrator
Staff member
Wiedemar, Germany
Joachim
I (@ralle89) wanted to introduce you to the motor vehicle for separating the engine and transmission.
- You must support the gearbox with a jack and secure the rear wheels against rolling away.
- The steering should be straight.
The car is attached to the tie rod and then the box section is screwed up until it rests on the oil pan.
Now the engine can be separated and can be moved on four wheels.
