Oil leak Zetor 8540
bjornmarius
Bjorn Marius Oyehaug
Hello! Bjorn from the west coast of norway here. I have to apologise for poor writhing, but i`ll do my best.
So it goes;
Bought earlier this year one Zetor 8540 which requires various maintenance and Repairs . just got clogged entire cooling system with new gaskets and hoses that sprang a leak . Oil leaks are next and this is something more comprehensive
After what I see now, there is leaking from a " drain hole" in the bottom plate between transmission and engine . Have talked to people around and heard them talk about fork seals in transition that should be replaced .
Someone who can be of assistance with parts , what a order, which ones use to be injured ? And when you split the tractor , you should then shift clutch / release bearing etc.?
Possibly complete repair kit can be purchased where fork seals / gaskets , plate and release bearing included ?
Maybe someone has tips and tricks in such repairs!!
PS .
Can fix photos, but is limited what you see in pictures such as tractor is now
Welcomes all tips :)
Some pictures;
http://i59.photobucket.com/albums/g303/bjornoyehaug/IMG_0142.jpg
http://i59.photobucket.com/albums/g303/bjornoyehaug/IMG_0146.jpg
http://i59.photobucket.com/albums/g303/bjornoyehaug/IMG_0149.jpg
I havent been around the UR3 too much, but i think the oil is leaking out of your clutch housing.
This can mean two things: the crankshaft seal is leaking, or the input shaft seal is leaking. And also the inside transmission cover can be leaking.
Can you see from the blackness of the oil, whether it is engine oil o transmission oil ??
i think i answer this in Norwegian Renze With Your permission.
Hei hvor i Norge er du lokalisert? kan du beskrive problemene p norsk til meg.
