Powersteering oil leak...zetor
geggs
Geggs
Under the front of the tractor a zetor 9540, there is a pool of powersteering oil.....it's gone in around the radiator and fan....any suggestions where it would be coming from?...
You have to clean the parts , and run for 1 minute and recheck . May be a fitting loose or a bad hose Mine has an hydrolic hose cracked and lost my hydraulic stering oil . I put a red oil in the powerstering . so ia can see if it is the spowerstering or another oil that i lost .
