Problems with handpump Zetor 6245 -86
pnystroem
Pnystroem
Hello, here is my problem.
The tractor went from running as it should to not run at all/or just on higher rpm's, to eventually die again.
I tried to start it later but could not get any fuel in the glass/optical filter.
So i checked the hose from the tank and it is not plugged, and the hand-pump seem to work properly. Removed all the hoses attached to the hand pump, no dirt or what so ever. I really dont get this, anyone who's got an idea?
// Patrick
Problem solved. Replaced the hand pump and the sealings to the pump manifold.
