Merry Xmas
I have just got a PTO Flat Belt Drive and the previous owner is sure that it is off a Zetor .
It looks as though it mounts over the six spline PTO shaft out the back and has 4 bolt holes on the mounting flange that just take 12mm bolts. 115mm centres. I have yet to measure my 7045 as I am away from it for a few weeks.
The 5011 - 7045 parts manual shows one but there are some differences evident. The 7045 diagram has a second bearing retainer plate for the bearing at the opposite end to the pulley on the pulley cross shaft.
The one I have uses the plate behind the pulley to access both bearings for the pulley shaft. Also the oil plug located differently.
If it is Zetor ( and many other parts look similar to the parts manual ) then the orange colour may signal Crystal. All the Crystals I have seen over here are orange.
Numbers on the casting are " D923299 " raised
and under that "RB2 " sunken .
http://www.farmphoto.com/thread.aspx?mid=891065&cb=1292752012727#891065
Any help with information will be very much appreciated.
These are not seen around much now days as modern machinery has gone away from flat belt drives. It would be nice to know what it is off.
Possible use I have is to drive a wood saw for cutting up trimmings form local scrub for firewood.
