I have a Zetor 8245 and the PTO shaft switches on and off. When on it turns but has no power. Does this indicate a fault with the hydraulic pump? Are there test points for checking the pump pressure/s? This tractor had very little oil in the transmission (less than 20 litres) when I purchased it. The previous owner declared the PTO problem and indicated he had not tried to fix it. Cheers
