I'm having a problem with my remote hydraulics. Is has the front end loader valve in the cab and the dealership put in their two joysticks in front on the standard contols right of the tractor seat. I've called the dealer and spoke with them and tried their suggestions of tying back the #1 remote contol arm (nearest the seat). You can see the hydraulic hose move on the disc cutter. I've unhooked the cylinder from the cutter, so there isn't any load on it. And the controls with pull the single acting cylinder in. But when hooked up to the cutter, it won't pull it up. I brought my Farmall 450 out and hooked the hose to its hydraulics, and it picks up the cutter bar no problem. I've tried hooking to all four remote ports and its the same. My front end loader and 3-point hydraulics are strong as can be. The draft control is in P position. I'm wanting to cut hay with this Zetor for the first time this Saturday. Hope someone can help .
