Reversor shifting gear don´t work.
lofjelld
Lars Ove Fjelldahl
My reverser shifting gear on my 6441 broke down. When I move the shifting level forward or backward, nothing happens. Is there someone who know what to do?
dont run it untill you are sure no broken pieces can fall between the gears, thats 10 times more expensive than a lever.. lift the transmission lid and you'll see what broke.. Nevr heard of breaking shift levers before, do you operate it as a synchromesh, or as a powershift ? ;)
Have you got the type with the lever on the side of the dashboard? If so it's cable operated. If it comes through the l/h floor upright panel, they break the shaft into the gear lever housing. There is a lock bolt inside the housing also which can come loose.
