Rookie about my Zetor 6718
klidde
K.Lidde
Together with our new house there was a tractor, a Zetor 6718. I have managed to start it and drive it for a distance. But now I have to fill it up with diesel and then I started to look for the filling hole. Is it the one, on the hood, infront of the front window? Then I also wonder how do you do to lower the rear hook? Is there a release clutch?
And do anyone have a instruction manual for this model?
Best regards Kennet
Yes, diesel tank is in the dashboard, you fill it right in front of the cab.
The rear hook, i suppose you are talking about the pickup hitch, which is standard in Scandinavian countries and Great Britain and ireland: Yes there should be either a direct lever, or a lever with bowden cable that releases the latch, so you can let the pickup hitch lower with the 3pt hitch.
In winter time you're going to need the cold start button... have you found it already ? its on the front of the fuel pump, it "clicks" into action if you pull the hand throttle first.
