still having trouble with FEL on Zetor 7245
dan_
Daniel
Need help I cant get the FEL to engage on tractor the rear hydrulics are working fine but no matter what i do i cant get the FEL to work ive changetd the PTO to 1000rpm and changed the small lever on left under feet to lowest position as was suggested but still nothing is there anything im doing wrong im sure its something simple but i cant figure it out. thanks for any help
check if not one of the hoses from the loder to the loader valve has worked lose one of the quick fittings, also are you shure the cables to the valve are working. can you hear the tractor work when you operate the loader joystic ?
how is hydrulic lines conectet to tractor? are they coected to pump direktly or at the eksternal copling att the rearend? iff coected to eksternal coplings you need to operate tath valve
when you want to operate the fel
if your tractor has a valve chest being fed from the back of the tractor,with a return in coupling 0,and the feed in coupling 1.bring the lever for hydraulics all the way back and hold it in that position by means of the fixing knob,this will send oil to your valve chest.
