- Joined
- Sep 9, 2012
- Messages
- 784
- Location
- Wiedemar, Germany
- First name
- Joachim
Torque / tightening torque for Zetor tractors
Please select the values that match your model!
All information provided without guarantee!
Zetor 15 - 25
(all information without guarantee! Conversion kgm/Nm: 1kgm/kpm = 9.8 Nm)
Motor:
Zetor Super / 50 Super
Motor:
Zetor UR1 2011 to 7341(1962 to 199
General default values from Zetor for the UR1 tractors:
Source: Zetor UR1 Series 1979 Engine Manual / Zetor, Motorkov
Motor:
Wheel, axle, front axle console (front):
Wheel, rear portal axle:
Steering:
General DIN ISO 898 standard values for screws and nuts
For all models if there is no factory default
Important:
Zetor 15 - 25
Motor:
Cylinder head nuts: 140 - 150 Nm
Wear as follows: (from No. 1 to No.
5 3 2 8
front - back7 1 4 6
Connecting rod bearing bolts: 100 - 110 Nm
Crankshaft balancers: 98 - 117 Nm
For more values see the bottom at the end!
Motor:
Stud bolts for cylinder heads, stud screws in the engine block: preload with 80 Nm
(according to RHBForttritt ZT, tip from @Dettl )
Cylinder head nuts: 180 - 200 Nm according to BdA
Tighten crosswise from the middle to the front/back!
Connecting rod bearing bolts: 147 Nm
Screws on the counterweight of the crankshaft: 35-40 Nm
Crankshaft main bearing bolts: 180 - 200 Nm
Motor:
- Stud bolts for cylinder heads(12 or 16 pcs.)
- M14x2 approx. 70 Nm (2011-5511)
- M16x1.5 approx. 80-90 Nm (4711-7745)
- Cylinder head nuts:
- Zetor 2011-4511 (M14x2 stud bolts) 118 Nm
to vehicle identification number (FIN):
2511 to VIN 23175
3511 to VIN 89420
4511 to VIN 53537
5511 to VIN 24349 - Zetor 2511-5611 (M16x1.5 stud bolts) 150-160 Nm
2511 from VIN 23176
3511 from VIN 89421
4511 from VIN 53538
5511 from VIN 24350
5611 from VIN 1001 - Zetor 4712 and newer (M16x1.5 stud bolts) 168 - 178 Nm
Attention - pay attention to the tightening sequence! (crosswise, cold engine, then let the engine warm up and let it cool down again and then tighten again when the engine is cold)
- Connecting rod bearing bolts: 80 - 90 Nm
- Nut for main bearing bolts: 103-118 Nm
- Crankshaft balance weights: 35 - 40 Nm (secure with locking plate AND liquid fuse!)
- Crankshaft pulley: 225 - 275 Nm depending on the model
- Flywheel mounting screws: 108-118 Nm
- Alternator pulley: 40 - 50 Nm
2x2 tractors
(2011 to 7321)
4x4 tractors with Zetor all-wheel drive axle (with cast star)
(e.g. 5945, 6945, 6045, 7045, 6245, 7245, 7745,...) with orig. Zetor front axle
4x4 tractors with Cararro all-wheel drive axle
(e.g. 5245, 3340, 4340, 5340, 6340, 7340, 7341)
Portal pivoting/height adjustment (field, care, vineyard):
2011: 50 - 60 Nm M14x1.5 according to BdA
3011 - 4011: 70 - 80 Nm M14x1.5 according to BdA
Steering:
elastic coupling of the steering column (from Zetor 5211):
5211 bis 7745: 14 - 15 Nm
Important:
The smaller value is for threads that are slightly oily (less friction = less torque required) and the higher value for dry assembly (more friction = more torque required).
Furthermore, all values here are only recommendations. I assume no liability for damage - if in doubt, consult the manual or the workshop!
Other sources for tightening values:
- Tightening torques of metric screws (external link)
