- Joined
- Oct 25, 2004
- Messages
- 47
- First name
- darylat8750
I'm new to forum so I may have not found a thread that address' this, but here is my problem. I have a 4341 that is a very satisfactory tractor. However, I live at an elevation of 8700ft. where a 60hp tractor puts out less than 40hp. The only job where more power is needed is moving snow. A 7 foot snow-thower just eats horsepower. If I added turbocharger part number 7701-1534 what other parts would I need? (Intake and exhaust manifolds look like they are the same, are they?) Obviously I will need oil lines ect. Now the big questions.
1. Are the exhaust valves the same in a 4341 as in a turbo engine or will I have to change to special valves?
2. How much power does this basic engine make in its turboed form at sea level?
3. How much power could I expect to get at 8700 feet with this turbo and:
a. stock injectors?
b. modified or different injectors?
4. Is there another turbine/compressor unit out there that makes sense?
5. If another turbine/compressor unit were found that could boost horsepower up to the 80 horsepower range, would the drive train stand up to it? (Assuming that any time I were using that kind of power most of it will be going out the PTO.)
6. Are these parts available on the used market? I'm rather price sensitive.
Thank you for your thoughts and consideration.
Daryl
a. stock injectors?
Daryl
