WHAT TYPE OIL IS USED IN THE REAR WHEEL GEAR BOXES OF THE 5011? THANKS
dferrera777
DFERRERA777
WHAT TYPE GEAR OIL IS USED IN THE REAR WHEEL GEAR BOXES OF THE 5011? THANKS
ALSO ANYONE KNOW THE 3-POINT LIFTING CAPACITY OF THE 5011? AGAIN THANKS
LOOKING TO MOUNT A WOODS 6.5 FT CUT PATH CHAIN FLAIL MOWER
Rear Portals ( reduction drives) SAE 80/90
3PT lift 1000kg
http://www.konedata.net/Traktorit/Zetor5011.htm
I thought a 6718 already lifted 1750kg, without assister ram. According to the parts manual , they all had the same main lifting mechanism, just the three cylinder had one assister ram and the four cylinders had 2 assister rams.
If your tractor has the assister ram, dont worry it will lift just about anything..
ITS A 3 CYLINDER , HOW DO I TELL IF IT HAS 1 OR 2 ASSIST RAMS? ARE THEY INTERNAL OR EXTERNAL. NOT SURE I KNOW WHAT THEY ARE? THANKS
REASON IS THAT ID LIKE TO MAKE A REAR FORKLIFT/ ROCK LIFT ATTACHMENT....
assister rams are mounted external. if yours has one, its mounted on the left hand side, on the crank that comes out of the rear axle cover.
