zeteor 10540 hydraulic spools
peterdiscovery
Peter
can you tell me which spool is for the hydraulic trailor brake on this 10540 zeteor tractor?? Also where the filler is for oil in the gear box and back axle??
thanks for your help
If you've got htb fitted it will have it's own special brake coupling which is totally different to the main spool connections.
The filler and dipstick are on the l/h side of the gearbox under the cab directly behind the hydraulic pump.
