Zetor 2002 3340 Hard Starting any advice??
papaj
Papa John
I'm thinking of buying a used 2002 3340. It has low hrs (under 200) and seems to be in great shape. I'm a little nervous about buying a "foreign" machine, not that I dont know that most are made out of the good ole USA today especially this size. Can any body give me some advice? I believe Im buying it right $$ wise. I will be using it at high altitude (8800 ft /3000 M above sea level) and this model is naturally aspirated. However it seems to start when plugged-in or using the block heater but is very hard starting when not pre-heated. Any advice I can get would be helpful.
Thank you
Papaj
I've got a 3320. Fabulous tractor. Extremely dependable, turns on a dime, excellent fuel efficiency. Not sure if they are easy to work on because mine never breaks (but it sure looks easy to work on).
Best all around small tractor I've ever had the pleasure to work with.
Tony in Louisiana
