- Joined
- Oct 25, 2010
- Messages
- 65
- First name
- greendragon3
hi zetor world kings , we have recently bought a very rusty 3011 which has lay outside most of its life, everything was seized solid on it but we have managed to free everything out except the diesel pump . it just doesn't seem to be getting diesel up to the injectors at all , it is devoid of a starter motor so we are trying to start it by towing but no luck , today we resorted to changing the pump with a spare we have from a 3511 but it still has the same problem , it is getting plenty of fresh diesel and it will prime up to all the bleed points no problem but noting is getting to the injectors so no go ............... we have blown all the pipes out with an air line and even removed tthe side plate from the pump to make sure the little springs were moving wich they are ,the replacement pump has been lubricated at all the right points and it came off of a working tractor , the original diesel filter must have been in it from new because they were in a very bad way so we removed them and we are running her without filters at the minute , would this have allowed grit to enter the pump and cause a blockage of some kind ???any help would be greatly appreciated , terry .
