I have a Zetor 3320 that has started to leak hydraulic fluid from two smooth holes on the bottom of the differential or rear end housing behind the transmission. Both holes are smooth without threads and they are both in front of the hydraulic pump housing. Does anyone know what these holes are for or what could be causing this leak. It is a pretty steady drip drip drip. I just replaced the seals for one of the front end loader cylinders and thought I finally fixed the last of the hydraulic leaks. Then this one started and I am at a loss.
I will try to post pictures tonight if I can figure out how to do that.
Thanks,
Thanks,
