- Joined
- Nov 26, 2016
- Messages
- 2
- First name
- Kytrailblazer
Hi. I'm a new owner of a used Zetor 3340 tractor. I wanted a tractor with 4x4 and loader and found this one. The main problem was that the brakes don't work unless you pump the pedal according to the seller. So as I unloaded the tractor from trailer I began to roll downhill and started pumping the brakes. No brakes no matter how much I pumped. Yes many thoughts went through my mind but was able to back up a hill and safely stopped. The brake fluid reservoir was cracked so I replaced it. Still no brakes but clutch works. I see a cover with a bolt on top of the rear axle and assume that it is where I bleed the brakes. Do I remove the cover and find the bleeder? Thanks in advance for the help !
