Zetor 3340 No PTO, 3 Point Hitch or Hydraulics
rickchambers
Rick
3 Point hitch and PTO was working, Shifted PTO into Neutral . When shifted back ,can not get PTO and 3 point hitch to work. PTO will work in ground speed only. Thank you for any help , I have a workshop manual but its a joke. Have not checked much because of weather but dont know what to check. Thanks Again.
did the C-pin in the lever break ? it happens all the time and can cause enough friction on the shaft to fool you, but still not move anything inside the gearbox.
I will check it Saturday, The tractor is my dads and I only get to make it up there on Saturdays. But I know it is shifting in and out of ground speed PTO. Thank You for a place to start looking.
OK found the problem, sanp-ring broken on 2nd shaft down in the gearbox letting one of the gears skip out of place. Still not repaired, have to order the correct snap-ring but it should do it. Slid the gear back in place by hand and everything seems to work.
