- Joined
- Feb 13, 2024
- Messages
- 141
- Location
- Windsor Vermont
- First name
- Robert
Hi Joachim, Thank you for your reply. Here is a picture of the info tag on the Zetor 3340 Loader Joystick Hydraulic Control Valve.Hi.
This will depend on your control block (front loader control block), but I think yes, it has a floating position to adapt to the ground. At least every front loader I've ever seen has had that.
Hi Joachim, I may have the tag upside down. This orientation may be the correct orientation. With that said, using the Loader Joystick I have not been able to see floating to be working so far.Hi Joachim, Thank you for your reply. Here is a picture of the info tag on the Zetor 3340 Loader Joystick Hydraulic Control Valve.
So the top of the info tag, I believe indicates moving the Joystick toward the front of the Zetor tractor.
Can you or anyone see where there may be a float position for this Joystick Control ?
Hi Joachim, Pushing joystick to the right is causing the bucket to curl down only.
Hi Joachim, Robert here again,
Hi Joachim, Thank you for your reply. Yes, I did not understand the arrow.What I mean with my arrow at the picture is the symbol on it. Not the direction to move it. There are 5 symbols they you tell in what position what function is given.
Could this lever be a safety for when working under the loader ?Hi Joachim, Thank you for your reply. Yes, I did not understand the arrow.
So the forward fifth symbol is representing a Float position for the Loader.
But this joystick does not have this Float position in it.
So maybe Zetor just put the same tag on all there tractors even though it may not have this feature.
Looking at the Hydraulic Valve Body out on the Quicke Q720 Loader, there is a Lever valve on the side toward the tractor.
Would anyone know what the function of this lever is ?
Checking out the Up and Down Cable at the Hydraulic Valve BodyHi Joachim and/or anyone,
Could the Joystick cables be out of adjustment causing the trouble of there being no float ?
No! - Safty is only given with a support under the loader or better at hydraulic cylinders.Could this lever be a safety for when working under the loader ?
Yes.So the forward fifth symbol is representing a Float position for the Loader.
Thats bad, but possible. The former buyer apparently didn't want to pay extra for this feature.But this joystick does not have this Float position in it.
Thats not a original Zetor loader. Loaders are alsways third party products. Up to around 2016 it was TracLift/Prima and then Alö eg.. So the Quicke loader at your Zetor is a third party device and the functions it have or not is what the former buyer apparently was willing to pay for.So maybe Zetor just put the same tag on all there tractors even though it may not have this feature.
I some cases its at the joystick side adustable, in some other is ther no way to adrjust it. And - dont use for the cable a mineralic oil. Use only a silicon oil there.I did not see where there may be an adjustment for the Cable.
Joachim thank you for your very good reply's,No! - Safty is only given with a support under the loader or better at hydraulic cylinders.
If its a two way lever, it blocks the pipe - but its no safety. Its only there to use (if closed) the hydraulic at the rear to tip trailers eg.
Yes.
If complete pushing forwar the joystick doesnt work for you, have you tried the other way? I some cases the cables are wrong mounted at the joystick and functions are not as the pics on it are saying.
I have not been able to find one that says with float yet. I found this PDF file about the WALVOIL SDM143/2New complete front loader valve with all what you like to have (valve, joystick, cable) will cost around 260-300 Euro I think.
You can take a look at Ebay, there are some listed.
It look like it may be to small of capacity for the Zetor 3340 system (I will need to find what the Zetor 3340 needs to have and in English too). In the sdm143a.pdf file on pages 11 and 12 there is mentioned float there. Not sure, but caused me to think maybe it could be out of adjustment with the relief stuff in the Hydraulic SDM143 Valve Body itself. Maybe it has been monkeyed around with by someone before me.Look:
*FK Söhnchen* | WALVOIL Frontladersteuergerät SD5/2 mit Kreuzhebel Seilzugventil 45l/315bar 2500mm WALVOIL Frontladersteuergerät SD5/2 mit Kreuzhebel Seilzugventil 45l/315bar 2500mm
WALVOIL Frontladersteuergerät SD5/2 mit Kreuzhebel Seilzugventil 45l/315bar 2500mm - Technische Spezifikation: Anzahl der Sektionen: 2 Nom. Volumenstrom: 45l/min. Max. Druck: 315 bar Verschraubung:www.fk-soehnchen.de
One of the first search results - a walvoil with float function as a complete set...
Hi Joachim,Its only a example - they also have bigger valves.
