hello, i have a 4340 that is sticking in reverse.it has shuttle shift. it shifts fine from neutral to forward, but you have to tap hard on the shifter to get it in reverse and once its in reverse, you have to tap very hard on the shifter to get it back. it drives fine onces its in. i took the cover off inside the floor of the cab, removed the selector lock, thats not it. i took the shifter for the 1-5 gears off to look inside . im not familiar with transmissions to know what its called, but i can see a piece that slides back and forth when you move the shuttle and its hanging in reverse, any help would be greatly appreciated, randy
