Zetor 5011 Hydraulic fluid in rams , emulsified ?
gramos
gramos
Kalispera , I have bought a Zetor 5011 and am in a steep learning curve , and would be very grateful for some of the knowledge here ? It runs well and the engine is very strong . The hydraulics have been slow to start and the bucket creeps down when loaded and I noticed a leak from the front bucket ram on one side . I removed both rams to put new seals in , the leaky one is 3mm bent with a few small marks but will press and polish out . Bad news is the fluid was milky in both rams . The trans oil was topped up last week and it is clean ,no emulsification at all . The tractor stood for a few months under cover prior to my buying it. The gears are a bit crunchy when first engaging ?
Is it possible that water has got into the rams without being in the transmission ? (it was stored rams in , bucket down )
