I have a zetor 5011(1983), with a steering cylinder problem. The fitting at the front of the cylinder where it attaches to the frame became worn and loose. I tried to tighten it but it was so loose the threaded portion at the front of the cylinder were stripped and the cylinder disconnected. When I tried to get parts as shown on the parts manual the part numbers shown were no longer in use and the parts were not available.
Although a substitute part may be available does anyone have another idea to fix the tread in the cylinder so I can reuse it. The fitting where it attaches to the frame will be replaced to eliminate the looseness at the frame.
Help !
Help !
