..The same reasons, different conclusions..
If the pushrods are unequally adjusted, your brakes are too. The clearance is also in relation with the "depth of bite" of your brakes, in other words: at what travel (or height) of the pedal, the brakes engage.
If your dealer tells different, he tells bull, perhaps he doesn't want you to listen to us, so you would come to him. (and scrape some more $$$ of your back...???)
Fuzzy bear just forgot about this: The hydro actuator system should auto adjust, like an automobile, to stay within the stroke. If the slave cylinders are more extended, it sucks up more oil to get the brake pedal on the same height.
The "having your foot on the pedal" story can only occur if the system is over adjusted. The auto-adjust will deal with the clearance, in normal situations....
About your "half wits" remark, i would appreciate it if you were a bit nicer to people that make an effort to
help you out for free.
Your dealer gets payd for what he tells you !!
