Zetor 5245
chaz
chaz
Hello all from Ohio:
I have a Zetor 5245 with frontend loader that I purchased about 2 years ago with 1300 hours on the tractor. My problem is the right front tire leans out slightly at the top, which is causing major outside tread wear. I have set the tow adjustment on the front axil and jacked the front of the tractor up and cannot find any play in the axil wheel bearing or camber bearing. Any helpful information would be appreciated.
Also the fuel injection pump is leaking fuel around the delivery valves. I understand that the pump can be sent to Pete at Zetor for rebuild or repair?
Thank You, Chaz
