ZETOR 6211 DIESELING BAD
raystheman
raystheman
CANT GET IT TO SHUT OFF. USED TO JUST PULL THE THROTTLE ALL THE WAY BACK AND IT WOULD DIE. NOW I HAVE TO PUT IT IN GEAR AND SET BRAKE. SEEMS TO BE GETTING WORSE.ANY IDEAS would be helpful
pull the pedal also! If is not enough you have to ajust the throtlle
on the end near injector pump!Good luck!!!
THANKS I'LL TRY THAT. IWAS TOLD THERE WAS A CUTOFF SWITCH BUT IF THERE IS I CAN'T FIND IT
