Hello.
My dad is installing a frontend loader on our zetor 6211. We have everything done except for the supply and return line. The hyd. pump is enclosed. Can anyone tell us where to hook the two lines up? The loader is a memo frontend loader.
Mine is ran through the hydraulic quick couplers at the back, which are feed and return for the loaders hydraulic block. Feeding off of the bottom of the pump plate is not hard, but getting the oil flow back to the 3pt requires extensive plumbing. Using above described method is easiest.
