Zetor 6245 Horsepower
jh
J-H
I hav 2 zetor 6245 from year 1986 and 1989. I need more horspower and wonder if its possible to adjust the dieselpump, and how mutch max HP is ?.
HP today is ca. 60.
I hav seen som of these with a turbo, is it orginal from from zetorfactory? or can i asemmbel one now.
You can easily open a 6245 up to 75 hp.
Turbo versions were only off the 7711/45 models with longer stroke. The 120 mm stroke engines do have the same connecting rods and crank diameters as the 110 mm stroked engines though, so 80 hp is achievable.
Thank you for reply.
If it can be open up to 75HP it will help .
I dont now how to adjust the dieselpump. I opened the cover at the rear end of the diesepump . and i think it is four skrews to adjust.
I need som tips how too do it !!
There are 2 big screws. dont touch the 10mm screws, only the slot screws that are secured with low 24 mm nuts.
I cannot remember if it is the upper or lower 24mm screw because a 5245 has only 1 big screw.
