The fluid tank, on the bulkhead behind the engine on the right ,is for brakes and clutch. Clutch is the small tank in the middle. Make sure its full.
Bleed screw on the slave cylinder on L/H side of tractor. bleed as you would brakes, but bear in mind the tank is small and will need constant refilling while bleeding.
