Zetor 6341 engine need work?
zipperno
Zipperno
I have a 2002 6341 with 4400 hours.
It uses some oil and now it has started to leak oil everywhere.
Its sweathing oil from dipstick, exhaust manifold, front cover etc....
Im guessing since it only sees light work its pressure in the engine due to pistions rings?
What are my options to fix this?
//Tom
Take the injectors out, split a liter of DOT4 brake fluid equally over all 4 cylinders, let it sit for 2 weeks, then put a rag over the engine and let the engine toll so the excess brake fluid gets thrown out. Install injectors back and start the engine. Let it warm up at idle (do not load the engine as brake fluid kills most lubricating capacities of engine oil) and once the engine is mildly warm, turn off the engine and change the oil.
Then with fresh oil, go to your neighbours farm and offer him to disk a field with a 15 foot disk, and give it hell for an hour or so.
We've revitalised compression in many engines this way, even an old Mercedes 280 that has been sitting for years.
Thanks Renze.
Ive heard about the brake fluid trick and then put it to hard work.
Its the middle of the winter here so my only option is to put a snowblower behind maybe.
But what is my options for the future? I only do light work with the tractor, will the problem come back?
What if I did a full overhaul? New liners and pistons. Same thing?
//Tom
yard tractors over here, usually get put in front of the slurry mixer in winter time to burn them clean. Too cold exhaust gases clog up the head passages, manifold and exhaust.
