Zetor 7011 cabin
thomas7011
thomas7011
Hi to all!!! im new member to this forum and i need a little help .
I have the zetor 7011 (my grandfather bought it in 1984) and it does not have cabin .i started to rebuild the tractor from the ground and i deside to put cab to the tractor but i cant find cab nowhere so the next step is to build one from the start.
i search the web to find any drawings fron cab to buid one but i didn't found.does anyone from this forum can help me with information/fotos or drawings to build one??
thank you all in advance.
Are you serious ? I mean, if you want to go cheap, you better build with what you can scavenge, and dont use drawings at all.
But then, its still less work to make a cab of an older model, eg 5718 or 6911 fit to the 7011...
If you really want to take the long, hard route, i guess there are plenty of photos in the internet to use...
Some welding on a used cab is allways better than to duplicate one from photos...
dont even think of building your own , the origional had to pass roll over and impact tests, youll be in all sorts trouble if youre caught by elf and safety. let alone involded in an accident.
