zetor 7011
tudor
tudor
Does anyone know anything about the 7011 I have been offered one for 3500 +VAT it only has 1400 Hrs .Is there anything I should look out for and does it sound like a good deal?! Any info. would be grately recieved. Thanks.
Check the hour counter is working as 1400Hrs for a approx 20yr old tractor is very low. A 7011 is worth between 1000 to 2000 in the UK!
They are worth more over here. The more you go to the east the more expensive they get. Our dealer imported a truck full of these models from england, to sell on to eastern europe.
7011 IS EXELLENT TRACTOR;). Check the cab floor for rust, ive seen guys fall through the floor;). The rubber mat holds moisture causing the shit russian metal to rust more than it was when they made it;). There is nothing much to look for apart from that!, Its always a problem on ( 0 ) series that the battery won't charge because of bad earth;) you need to re-wire the tractor completely sometimes:eek: for 3500 i would rather look for 7045 4wd;). more than 2500 for 7011 is rip off???
