Ive got a Zetor 7711 on which I have replaced the master clutch cylinder with a new one. Hereafter I have flushed the clutch system for air and now I cant put the tractor into gears. To get it in gear for moving the tractor from the repair place I extended the shaft out of the slave cylinder. When pushing he pedal in the cabin 100% down the movement of the shaft out of the slave cylinder is 16mm and it is moving as soon I touch the pedal, and there are no leaks anywhere. Do anyone know if this movement of 16mm out of the slave cylinder are the correct movement, because right now I have pre loaded the clutch due to the extended rod out of the slave cylinder?
Tanks in advance
Best regard
Winkler
Tanks in advance
Best regard
Winkler
