question Zetor 7745 low gear problem??
hyunday
waling paulusma
hello
my Zetor 7745 acts likes i brake ,when i drive in low gear, and
using the clutch the tractor stops without using the brakes,
in highgear it works well.
is there anybody who had the same problem, i dont now the reason but are thinking maby bearing because it makes some noise.
thanks w.p
Never heard of that failing, but worth investigating.
Pulling the reduction shaft requires a special pulling tool... which i made myself.
yes strange men i wil describe the broblem afther repair,
traktor sounds terrible.
i hope there is some one who had the same problem.
could be easier to repair.
waling
did any one had problems with the reverser,omkeerversnelling (nl),vendegir (N) because, is it possible that both revers and forward are connectet that should give friktion ?????????????????
maby the gear shift fork is bent?????????
