question Zetor 8011 - clutch trouble
Eusebiu
Timișoara, Romania
Eusebiu
Zetor 8011
Bună ziua as avea nevoi de ceva ajutor am un zetor 8011 și ma confrunt cu ce a probleme dacă ma poate ajuta cineva, la cuplajul aplificatorului de putere patinează și nu înaintează tractorul știe cineva care ar fi problema?? Multumesc
Hello. I don't understand what you have wrote, but using google translate and if it is correct. You are saying your hi/lo isn't working on an 8011? If so 2 things could be, either your torque band is broken or your torque pump is knackered. Unless it is something simple like the linkage has fallen off or slipping on the top of your gearbox, you are facing a serious bit of an operation required on your tractor.
Mulțumesc foarte mult o informație de mare ajutor..... Ar m-ai fi o problemă cu care ma confrunt la bratele de ridicare ridică foarte bine dar nu rămâne blocat tot lasă jos care ar fi problema(am schimbat și pompa și garniturile la cilindru din bloc)mulțumesc inticipat
Sorry now, I translated your problem but I don't know what it means by not get stuck? Do you mean the arms goes down by itself? If that's the problem. The seals in the cylinder under the lift cover is usually the problem.
@Eusebiu
Welcome at Zetorworld, Eusebiu! :)
Please write in English - use google translator for and write it simple so the translation can work proper.
@diyfarmer
  1. Its lifting mechanism does not hold the set position; it lowers itself.
  2. The powershift clutch slips and the tractor does not move forward.
Thats what I translate from him to German and back to Englisch.
Last time - English please, or I have to close this thread. English is also not my native language and I can also translate from German to English so you can do it same way and other members have it much more easy to answer your questions.
Take a look at our terms and rules you have read bevor you have registered your account.
