zetor 8011 hydraulic problem
buzzey
pat
i have a problem with my hydraulics not working on a 8011 zetor , i took off the hydraulic pump and the shaft is not turning inside that runs the pump. has anyone saw this problem before? is it a big job to replace that shaft, what do i need to do?
somewhere under that side of the cab theres a lever to put the pump drive in and out of gear, check that as a first step.
yes i saw that , had to remove that leaver to get in at the pump, their is a H and 0 position on the leaver, the rod is out so thinking its in H position, and it should work in h position as i looked at other tractors.
