Zetor 8011 Injector Pump
tomwilt
tomwilt
My 8011 has a fuel leak behind the injector pump. Looks like I will need to pull it off. Hard to get to the back bolt, but I will eventually get it off. I have parts manual but there is not a clear illustration of the back side of pump. Just wondering if there is a place it could be leaking on backside of pump and if my diagnosis is correct or could the leak be coming from someplace else behind the pump.
If the pump is similar to the UR1 pumps, there is a fuel hose connection behind the pump. I ripped a rear view mirror out of an old car as a workshop mirror, to look in difficult slots and crevices.
I know the leak your talking about as my 8011 has the exact same leak, so bad infant I Goto turn the fuel off after I use it then bleed it up later so would very much like to also know the solution to this.
