Zetor 8011: locked rear wheel in cold temps
bristol
Bristol
The colder it gets, the harder it is to make my tractor right rear wheel turning. Any idea why? Water in the real axel reservior? Break reservoir? Any help appreciated. Thank you
Today in -20 degree C, I took me 10 minutes to make it move. Tried forward and backward gears many times. I was able to make a U turn without having the right rear wheel turned a bit! Never used the difrencial lock or .... what could be the cause? Thank you
Thank you, Mike
If that is the cause, I will be on the mission to replace the cylinder once the weather permits here in Canada.
The same wheel has oil leakage from axel seal. Could that be what started the problem on the first place? Thank you
do you park with the handbrake applied? if you do it could be ice or frozen mud jamming the linkage.
as the linkages and even the slave cylinders are all visible on the crystal it should be easy to see if thats the problem.
I don't ever have to use the hand break since my property has hardly a pump! The linkage seems to be ok . I may have to wait till spring to see if the problem persists in warmer temp. Thank you
