- Joined
- Dec 31, 2009
- Messages
- 11
- First name
- jfraley
Hello all!
I'm having a problem with oil leaking above the oil filter on my Zetor 9520. This old girl has seen some rough times. It was leaking when I got the tractor. When I changed the fluids I had to cut the oil filter off it was on so tight. I'm not sure if the pressure is so high its leaking or if the leak is on the bottom side of the fitting the filter screws onto.
I've always had great success asking for help on here. I'd appreciate any help on what the issue might be.
Thanks!
Thanks!
