Hi Everyone,
I picked up a new-to-me Zetor 9540 on Saturday that so far I love! It does have two issues that I would appreciate some help on. For one, the hour meter doesn't work. The tach works fine and I looked through and wiring and didn't find anything cut/disconnected that might cause the hour meter to not be reading. Is this a common problem? Is there a simple solution?
The other issue I'm having is a hydraulic fluid leak out of the brakes. It isn't on the slave cylinder as best I can tell, but higher than that where it actually goes into the housing. Is it an o-ring in there that may be bad?
Thank you and I look forward to being on the forum!
