Yes i can imagine it.. Indeed the
Zetor Crystal torque amplifier was much beter and evolved than the rest, back in 1968 when they introduced it on the Crystal.
Deere's system on the 80's hi/lo power synchron trannies was not a direct copy. I dont know about Ford, but MF used a freewheel clutch in it, if the multipower clutch was engaged it multuiplied speed, when it was released it freewheels till the speed of the freewheel clutch matched the speed of the shaft, then it catched on. Like a bike, if you are driveing and stop the pedals, the bike is not driveing your feet on the pedals, you can keep your feet still while the bike is drveing.
Zetor used a planetary gear with two clutches: one band clutch around the ring gear, and one clutch inside the planetaries. The clutch inside the housing was continously engaged by springs, and disengaged by oil pressure. At the same time the oil pressure would engage the band clutch around the planetary ring gear. So even if oil pressure wasn't there (engine off) at least one of the clutches would be engaged.
On Ford Multipower, if the control mechanism wore out, it would freewheel for about 5 seconds before the next step would engage. This is because both clutches needed the oil pressure.
Zetor's system is absolutely trouble and maintenance free (i have never ever heard of a Zetor torque amplifier failure) because there is no need for a regulator mechanism. It was operated by ONE oil remote, pressurised or not would mean shift or not. Not a tricky set of valves that needed adjustment or were a weak part.
Deere indeed copied the idea of the two clutches, one pressure engaged and the other disengaged. But that was 15 years later, in the early 80's......
MF used just one clutch and a latch/camwheel construction. Ford did use two clutches but the problem was the operating system that needed calibration.
I dont think that Deere's system was a license, i think they just copied/stole it (as they always do...) Maybe they added electro-
hydraulic control switch in the main gear lever ?
