zetor brakes
frosty
Hi just need a little help
I was looking on some website and found a form with a zetor being fitted with air breaks off a fast track.
Iv heard of zetor 12145 being fitted with wet breaks off a ford not sure what sort.
But on another sight i heard a bloke fitted breaks off a jcb fast track got the discs made up and used the air systems to work it off the peddle.
I can't find the form anymore it seems to be removed.
Has anyone heard of this, is it even possible ?
Would be wonderful if it could their breaks are rubbish.
your right about the conversion to wet brakes seen some done by the drain hole being blocked and a oil seals on the shaft removed on the diff side ..and different gruffo's on the brake shaft / rod ...some work some are poor sealed and weep like hell .,,,as for fitting air brakes to the back of a crystal axel is near on impossible ...but you can fit a air over oil system but it still use's the zetor slave cylinders...which are the weak point really ..there's always fitting of the prop shaft brake from the 9540..they help but are a bit of fun fitting them and need to t the pipe work for fluid ...but they help pull them up when you've a loader fitted ...
