FAQ Zetor colors and paints - Zetor Original, RAL, tips
Status
Not open for further replies.
Germany Joachim
Administrator
Staff member
Wiedemar, Germany
Joachim
Colors and paints - Zetor Original, RAL, tips
All information without guarantee! - Status: October 7, 2024
There it is again - the question of the original color. :D
Most people think - Zetor are red. But that's not quite true, because the first Zetors came onto the market in army colors, due to the post-war period. There were also dark green Zetors for the Basilian market, orange ones for the Japanese market or the blue UR2 Zetors for the East and the red ones for western export. There were also Zetors in John Deere colors (green/yellow) that Zetor produced for JD (series 2000, 1993).
To still offer a little help with the color choice, here are the most common color combinations.
Please scroll all the way down to see all the color information by series!
Sources e.g.:
- Ersatzteilhandel Weisse Zetor paint colors!
(all Sparex(Agricolor and paints in cans or sprays in very good quality)
or e.g. billigspray.at - all Zetor colors in all gloss levels as acrylic paint
Tips:
1) 1K synthetic resin paint + 10-15% "hardener thinner" ensures faster drying and a more durable/harder paint. It is best to use the same manufacturer of paint and thinner/hardener thinner or test for compatibility beforehand!
2 ) Synthetic resin paint on acrylic paint and vice versa - is that possible? Yes, if the drying times are adhered to or if you are painting over old paint. With new paint, at least 3 days at around 20°C should have passed, or longer at lower temperatures, before you can paint over it.
If necessary, there are 2K epoxy separating layer primers to reduce the risk and avoid having to completely remove the old paint.
Zetor 15 - 50 Super
These models were painted in a variety of colors.
Depending on what was available at the time, such as surplus army stocks of green and khaki, they were then painted.
Very often the tractors were also painted in the colors of the importer or dealer after export, such as orange for Japan.
In the second half of the 1950s, brilliant blue (the original blue of the corporate Zbrojovka weapons factory) became the standard color for Eastern Europe and traffic red for export to the West.
Added by @Henrik Juhler (Zetor collector, Denmark)
In Denmark: the first Zetor's 25 (until 1951) had army color and dark red wheels. (Front wheels: army color on the inside and red on the outside. Rear wheels were red).
1951 to 1961, Zetor 25: the red color with yellow wheels (front wheels: red inside and yellow outside) rear wheels were yellow.
In Sweden: the blue color with yellow wheels
In Finland: the green color with yellow wheels.
Here are some of the color codes used:
Zetor 25 A/K
Zetor Super / 50 Super
Primer: red-brown but rims light grey or white​
Red = ČSN 8140 / a little lighter than RAL 3020 (satin matt glossy)​
Green = ČSN 5300 / RAL 6001 (satin matt glossy)​
Blue = ČSN 4399 / a little darker than RAL 5015 (satin matt glossy)​
Yellow = ČSN 6350 / RAL 1021 (satin matt glossy) or ČSN 6202 / RAL 1016 (lighter) (satin matt glossy)​
Yellow-grey/beige = ČSN 0921 / RAL 7034 (satin matt)​
Zetor 2011 - 4011
Bonnet, wheel arches, fenders, Rims:
███████ Blood orange RAL 2002​
- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90% (satin matt)​
(e.g. Kramp synthetic resin paint)​
or:​
- Mixing: 95% RAL 20​
02 + % RAL 3020 to make it look slightly less orange​
or:​
- Sparex S.82420 or S.92420​
or:​
- ČSN 8130 ( 8131 ) similar to Porsche Red​
- synthetic paint S 2046 / 0815​
or:​
- ČSN 8140 (vermilion red, darker)​
or:​
Note from @Henrik Juhler (Zetor collector, Denmark):​
"The orange color for the Zetor 2011 - 4011 I bought from SPAREX:​
- Color number for 1 kg cans S.82103​
- Spray 400ml S.92103​
Engine/gearbox/frame:
1728328693539.png Gold beige metallic from Kramp or Sparex​
(mostly export version) Here in the photo: Gold beige metallic and Zetor red-orange from Kramp​
or sometimes not so "golden":​
1728328723858.png Olive yellow RAL 1020​
- (mostly domestic CSSR version, but sometimes also found in export (DK))​
- (e.g. Kramp synthetic resin paint or "olive yellow" RAL 1020 from ESBJERG PAINTS)​
- Note from @Henrik Juhler (Zetor collector, Denmark):​
The frame color is "olive yellow" Ral 1020 (unfortunately varies depending on the paint manufacturer) and fits a good 95% of the time. You won't get it 100% right because the original paint had some silver mixed in, which you can't get like that."​
Olive yellow RAL 1020 + Sparex Orange S.82103 (better or a little darker: Sparex Red-Orange S.84266​
And another tip from CZ:​
The base is metallic color RAL 1020: (recipe for polyurethane paint):​
The base is the color RAL 1020.​
The color system is RAL TELURIA color system.​
1L RAL 1020 and:​
+ 8.50 g black pigment 1898​
+ 15.0 g ochre pigment 1867​
and the resulting mixed color is mixed 1:1 with the silver paint bought in the store "Chemopur E colors 9111 silver" mixed.​
A frequently mentioned color mixture for a reasonably suitable color:​
70% light ochre RAL 6700 + 30% aluminum RAL 9110​
or:​
- ČSN 0921​
- synthetic color S 2046 / 0921​
If that works... try it out and report back. ;)
Exhaust, manifold
███████ Black RAL 9005 / ČSN 1996​
- Gloss level according to ISO 2813 (at an angle of 60˚) = 20 – 35 % (satin matt)​
(e.g. [uri=[URL='http://www.eightball-custom.com/VHT-Auspuff-Ceramic-Coating-1100C-schwarz-matt']Care products - Eightball Custom[/URL]]VHT exhaust Ceramic Coating 1093C° black-matt[/uri] pre-treat with​
Orig. VHT primer for ceramic coating up to 1093C° heat resistant)​
For the domestic market in CSSR and export to Eastern Europe:
Source: Google search​
Bonnet, wheel arches, fenders, rims:
███████ "Brilliant blue" RAL 5007 / ČSN 4399 (satin matt-gloss) according to Mr. Šubr from Zetor Tractors a.s.
- synthetic paint S 2046 / 4399​
Some also use "light blue" RAL 5012 as is sometimes reported in the Czech Republic.​
Engine, gearbox, frame, weights:
1728328811748.png Olive yellow RAL 1020​
(e.g. MIPA Mipalin synthetic resin paint or "olive yellow" RAL 1020 from ESBJERG PAINTS)​
Zetor 2511-5545, 4712-6745
- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (satin gloss)​
or mix: 95% RAL 2002 + % RAL 3020 to make it appear slightly less orange​
1728328903944.png Zetor Goldbeige-Metallic Sparex S.82193 or Kramp​
- Gloss level according to ISO 2813 (at an angle of 60˚) = 20 – 35% (satin matt)​
If you want to mix it yourself, you can do it here try:​
no guarantee! if you want to be sure you should use the Kramp or Sparex colors​
44.4 % ocher brown ČSN 6700 / RAL 8001​
44.4 % aluminum ČSN 9110 / RAL 9006​
11.1 % chestnut brown ČSN 2880 / RAL 8017​
Original <> mixed color​
Examples where it didn't quite fit: Zetor 3511 from @Bodo
Color: Asinol Olive Metallic (more inappropriate!)​
Color: Kramp Zetor Goldbeige (very similar to Sparex Goldbeige-Metallic)​
Do you have comparison photos like this? Then bring them on! :D ;)
Exhaust, manifold
███████ Black RAL 9005 / ČSN 1996, ČSN 1999​
Zetor 4911-6945
- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (satin matt)​
1728329008658.png ČSN 0921​
- synthetic paint S 2046 / 0921​
- gloss level according to ISO 2813 (at an angle of 60˚) = 20 – 35% (satin matt)​
Exhaust, manifold
Orig. VHT primer for ceramic coating up to 1093C° heat-resistant )​
Zetor 5011 - 7045
Primer: Reddish brown but rims light grey or white
Bonnet, wheel arches, fenders:
███████ Black green RAL 6012 / ČSN 5914 / S 2053​
or:​
- Black RAL 9005 / ČSN 1996 and pine green RAL 6028 / ČSN: 5420 (or dark green ČSN: 5400) mix to match​
or:​
- Darken black green RAL 6012 / ČSN 5914 with a little bit of black RAL 9005 / ČSN 1996​
Rims, roof
███████ Pearl white RAL 1013 / Cream white ČSN 6002 (slightly darker)​
INDENT=2]- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (satin matt)[/INDENT]
(e.g. Kramp synthetic resin varnish)​
or:​
███████ Light ivory RAL 1015 / ČSN 6006 or ivory ČSN 6003 (slightly lighter)​
Oil bath air filter type MANN
███████ Sky blue RAL 5015​
Exhaust, manifold
(e.g. [uri=[URL='http://www.eightball-custom.com/VHT-Auspuff-Ceramic-Coating-1100C-schwarz-matt']Care products - Eightball Custom[/URL]]VHT Auspuff Ceramic Coating 1093C° schwarz-matt[/uri] pre-treat with​
Zetor 5211 - 7745 Turbo
Old color scheme:
(as with the 5011-7045)
Primer: reddish brown but rims light gray or white
Bonnet, wheel arches, Fender:
or mix: 95% RAL 2002 + % RAL 3020 to make it look slightly less orange​
or:​
- Mix black RAL 9005 / ČSN 1996 and pine green RAL 6028 / ČSN: 5420 (or dark green ČSN: 5400) to suit​
or:​
- Black green RAL 6012 / ČSN 5914 with a little bit of black RAL 9005 / ČSN 1996 to darken​
Wheels, roof
███████ Pearl white RAL 1013​
or:​
███████ Light ivory RAL 1015 / ČSN 6001, 6003, 6006​
or:​
Exhaust, manifold
Newer color scheme:
Zetor 3320 7340 Turbo (also occasionally found at 5211-7745)
Primer: reddish brown but rims light grey or white
Engine/gearbox/frame, dry air filter, cabin
███████ Black RAL 9005 / ČSN 0199​
- Gloss level according to ISO 2813 (at angle​
- Paint adhesion according to ISO 2409 = grade 0 – 2​
Roof, rims (depending on year of manufacture/model)
- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90% (satin matt glossy)​
or mix: 95% RAL 2002 + % RAL 3020 to make it look a little less orange​
or:​
Rims (depending on year of manufacture/model)
or:​
Exhaust, manifold
(e.g. [uri=[URL='http://www.eightball-custom.com/VHT-Auspuff-Ceramic-Coating-1100C-schwarz-matt']Care products - Eightball Custom[/URL]]VHT Auspuff Ceramic Coating 1093C° matt black[/uri] pre-treat with​
Zetor 3321-7341 Super, UR1 Major and early Proxima
(also some early Proxima)
Bonnet, wheel arches, fenders, roof:
███████ Traffic red RAL 3020 / ČSN 8142​
- Adhesion according to ISO 2409 = grade 0 – 2​
Rims (depending on year of manufacture!)
until the end of 2007:​
from 2008:​
███████ Pearl white RAL 1013 see 2nd picture​
(e.g. Kramp synthetic resin paints)​
Exhaust, manifold
(e.g. [uri=[URL='http://www.eightball-custom.com/VHT-Auspuff-Ceramic-Coating-1100C-schwarz-matt']Care products - Eightball Custom[/URL]]VHT Exhaust Ceramic Coating 1093C° black-matt[/uri] pre-treat with​
Zetor Proxima plus
Bonnet, wheel arches, fenders, roof, dashboard:
███████ "Traffic red" RAL 3020 / ČSN 8142​
- ČSN 8331 – 8335​
Until the end of 2007, except Proxima Plus:​
███████ Light ivory RAL 1015 "Zetor light ivory"​
From 2008, as well as side panels and front grille:​
███████ "Silver" ("White aluminum") RAL 9006​
(e.g. K​
Exhaust, manifold
Zetor 8520-10540
- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (semi-matt gloss)​
- ČSN 8331 – 8335​
Engine/gearbox/frame, dry air filter, cabin frame
Wheels
███████ Zetor Ivory "Light Ivory" RAL 1015 / ČSN 6001​
- Gloss level according to ISO 2813 (at an angle of 60˚) = 80-90% (semi-matt glossy)​
Exhaust, manifold
Zetor UR2 Crystal 8011-16045
Bonnet, wheel arches, fenders, roof, rims, dashboard:
- ČSN 8331 – 8335​
According to a source from CZ, with reservations, possibly also ČSN 8191 (between vermilion and cherry red and therefore darker than traffic red)​
1728329551907.png Olive yellow Ral 1020 (matches 95%) / ČSN 0921​
- gloss level according to ISO 2813 (at an angle of 60˚) = 20 – 35 % (satin matt)​
Roof:
███████ "Cream white" RAL 9001 / ČSN 6003​
- gloss level according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (satin matt glossy)​
Exhaust, manifold
Zetor Komunal tractors
Bonnet, wheel arches, device:
███████ RAL 2011
- Gloss level according to ISO 2813 (at an angle of 60˚) = 80-90% (satin matt)
- Gloss level according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (satin matt)​
from 2008:​
- Gloss according to ISO 2813 (at an angle of 60˚) = 80 – 90 % (since​
matt glossy)​
or very rarely:​
Colors according to paint manufacturer
Kramp Information according to Kramp catalog! follows... see ETH-Weisse.de
Sparex Information according to Sparex catalog!
███████ Zetor 2011-5511 (?) - "Orange" No. S.82103 (like Fahr up to 82 and Veenhuis) similar to RAL 2002 blood orange
███████ Zetor 4712-4718 - "Gold beige metallic" No. S.82193
███████ Zetor 4712-6711 - "Orange Red" No. S.82420 Zetor from 1992 - Orange Red No. S.84266 ███████ Zetor 5711-6711 - "Green Beige Metallic" No 97 ███████ Zetor from 1981 - "Dark Green" No. S.82841
███████ Zetor from 1981 - "White" No. S.82840
Fliegl
Zetor Red LM 0221
Zetor Dark Green LM 0271
Zetor White LM 0296
Mipa
MIPA Mipalin vehicle paint synthetic resin paint LM 0271 Zetor Dark Green
MIPA Mipalin vehicle paint synthetic resin paint RAL 2002 Zetor Orange ("Blood Orange")
MIPA Mipalin vehicle paint synthetic resin paint LM 0221 Zetor Red
MIPA Mipalin vehicle paint synthetic resin paint LM 0296 Zetor White
Sources:
- "The Zetor Book"
- paint shop Gau in Glesien Germany
- Notes from our members at Zetor-Forum.de (e.g. David Welk, Matthias Pieper, Henrik Juhler and others) and from the forum here
If you have different information or additions to offer, please feel free to write it us. :)
Status
