Zetor Compressor
swallowsretreat
swallowsretreat
I have a Zetor 6211 1991.
Is there enough output & pressure from the Tractors air compressor to run a paint sprayer???
It will run a sprayer, but not very well, you will have to make a "T" to feed into a large truck type tyre so that you have a large reserve of air at no more than about 40PSI. This will give about 10 mins of spraying before you have to wait for the tyre to pump up again.
We have also used a type of sprayer where the air is going through the sprayer all the time, but the airflow was slightly too low to get a good result.
you can spray /use air guns etc with a zetor air supply no problem almost all zetors run at 7-9 bar of pressure for trailer brakes etc...all you need is a fitting to go in the end of the air tank under the cab and a pipe with a female psl fitting on the end then plug in your air tool and away you go ..
7 bar is about 100 psi, is there some sort of relief valve on a 5011? I don't want to destroy any air tools...
