Recently got a 1978 Zetor Crystal 8011 and i want to give it a full service. I have some questions i hope someone can help me with.
1. Do i add Oil to the air Breather basin. we used to have a MF35 and you added oil to the basin of the breather.
2. Are the markings for lining up the centrifugal oil filter clearly marked or obvious when i take it apart.
3. When draining the engine oil i cannot get the Nut to open. There is another nut slighlty below this one i opened it slighlty and water came out - What is this for. Should i drain it. Perhaps i am not in the right place to drain the oil ?
4. Where do i drain and then fill the back end oil?
5. There is an hydraulic screw in oil filter on the right (as you look from the front) of the tractor under the cab. There is another metal housing underneath this looks like a filter could fit in there. do i need to do something with this.
