Zetor Crystal 8011 - Replacement Injectors
shanehanlongmailcom
Shane
Hi all. Not entirely sure of the mechanical workings of engines but my fathers Zetor Crystal 8011 (1979) sounds like it is not firing correctly.
A mechanic tells him that he has the wrong injectors (another mechanic replaced these a while back apparently).
How would I go about identifying what the correct type of injector is for this tractor?
And where could I buy them? (the tractor is located in Ireland but I'm in London).
Hi.
The injector nosle for the 8011 is DOP150S4281416, any Zetor dealer shold be able to sourse them. You will nead to have them installed in the holders and set for presure by a dieselshop.
Cheers for that. Now to find someone in Ireland to supply them, or...
Not knowing engines - are the injectors large items? More specifically, would I get away with putting them in a carry-on sized suitcase?
I'm in UK but tractor is in Ireland and might get the injectors here and bring them back with me.
Hi I have new injector nozzles in stock for your Zetor Crystal & can offer a fitting service if required by post or carrier call me on 07870933540 or www.zetor-dealer.co.uk
If you do decide to DIY fit nozzels, they have marks on the body and tips that need to be lined up on assembly.
If you havn't the gear to test them, I would take Alzets offer, they are profesional and reliable and you will end up with injectors at the correct pressures and settings.
DaveP - your recommendation is noted. Thanks.
Alzet - the tractor is in Ireland (I'm in London myself) but am heading back to spruce it up for my father as much as I can.
So I'll forego the fitting service but will possibly place an order.
Let me confirm how many injectors are required and in the meantime can you message me (or post here publicly if you like) a price inc. delivery to London (post is fine). Cheers.
Where in Ireland is the tractor? I would buy them from the local dealer because if they are wrong they can easily returned.
Hi Shane, Galway was always a stronghold for Zetor. I don't know where the dealers are in Galway but go into zetor.ie and they will email you the location of your nearest dealer. Have you thought about getting the old one reconditioned?
Have dropped Zetor.ie a mail Lenny.
Have also enquired with the machine owner as to how many injectors he has an issue with...no surprise that he doesn't know. But now he maintains that new injectors were bought a year or two ago, so...they're either the wrong injectors or, something else is causing a problem (which is it is misfiring, and lacking power in high gears).
Any spending on injectors is on-hold for now until he can tell me what the problem is exactly.
Thanks for all the help guys. Will come back to these posts when I'm more aware of what's going on.
