Hello, I recently purchased an beaten up Zetor 8011 which runs well. It had a very little leak of coolant from the bottom cover coolant gasket (sump gasket?). I tried to tighten the bolts, I have broken two of them and now it leaks even more. I am thinking I need to change the gasket and use new bolts. Can anyone please tell me if it is something I can do it myself? I'm not a mechanic, but can open/tight bolts!! When I go to purchase gaskets, all I can find is "Gasket set, Lower". Is it the right gasket? Here is the link of the gasket I am going to buy from.
Thanks in advance!
https://www.allpartsstore.com/ItemDetl.htm?B2BSessionID=130506070207587&CategorySeq=M&SelcBrand=ZT&SelcMachn=TRACTOR&SelcModel=8011&SelcSectn=E&SelcSubsc=E70&SearchItem=1&TextSearch=&ItemNumber=84020025
Thanks in advance!
