zetor dynamo
Go to the scrapman, find a really old car (ford sierra,escort,landrover ect) remove the altenator And bolt it on your tractor:D It is simple to change the electrics;)
That should work, You need one that turns the correct way though! Make sure it is bolted to the same side of the engine as the zetor ;) Landrover ones should work??? but avoid the ones with Electronics and brake servo coppressors. It would be best to take the dynamo to an auto-electrician first, maybey it only needs a clean:)
the dynamo of mine is bugered the previous owner has kept running it with seized bearings. i shall ask my friend at college he is a ford and land rover man to see what he has got:D
