Zetor high crop?
jed
jed
hello all
we're looking for a new high clear/high-crop tractor like a case jx95
JD 5525hi-crop but jd's are costly and the case jx series seems
to suck, I've met a few very happy zetor owners and I though we
should look at one needs to be a high crop with creeper gears and
MFWD in the 60-80hp range and needs to run hydraulic motors off the remotes.
You can mount very high tires under them. On our 6718 we moved the cab up 2 inch to make room for 34" tires like a 7211 has.
You can also roll down the rear portals one hole, this is how the original high crops were made in the 60's. With a 2wd front axle you can still get extended hub kingpins from the older series i think.
