question Zetor Proxima 7441 front axel leak
tommy_dunne
bunterd
Hi all..
My zetor 7441 has developed a leak in front axel behind the hub and is runing down the inside of wheel.
Question is about changing that seal?? Like is there just a big nut under holding on the hub in the middle of the planetery gears or is there more to it?? Thanks folks
Hi all..
The satellite carrier is under the hub. open the nut first then the bearings, pull them off then slide off the carrier. the seal is on the inside so it's a bit of a job.
Should asked first, if your axle is a Zetor type or a Carraro type? because they are different.
